Sonex 815 Build Logs
Date: 9-26-2009
Number of Hours: 4.00
Brief Description: Annual inspection
Did the annual per part 43, appendix D. Battery checked at 12.94 V. Need to change the ELT batteries. Torqued prop, cyl heads, plugs. Air into tires. Engine compression #1 80/76, #2 80/74, #3 80/75, #4 80/77, #5 80/74, #6 80/76. I dont think I figured out exactly how to do this until the 2nd to last one, but all these values are high enough that I'm not worried about it. Found one nut loose on the L aileron pushrod at the outboard end of the long pushrod. The pushrod itself can't unwind, though, because the inboard end was tight, and even if both ends were loose, as one unwound, the other would wind in, eventually bottoming out. Didn't find anything else of significance. Put the tail and wing access covers and tail fairings back on. Will finish up the seat, seat pad, cowling, and gear fairings later.
