Tightened up the mixture cable clamp on the aerocarb. Need to add some clamps to the throttle and mixture cables to keep the mixture cable off the left spark plug leads. Started installing the left air vent tube. Got the forwards end attached. Will need to pull the panel off to do the aft end. Rolled it outside and checked the radio and intercom. Intercom seems to be working, but no audio from the radio. Not sure if that means the radio audio isn't making it to the intercom, or if the radio antenna is bad, or if the radio is bad. Radio powers up ok and I can see the channel and presets. Bought the break-in oil at the FBO.
