Sonex 815 Build Logs
Date: 6-2-2007
Number of Hours: 2.00
Brief Description: Placed orders
Spent a while going through all the notes and lists and made up orders for Wicks, Aircraft Spruce, and Summit Racing for what I hope are the rest of the mechanical parts for the panel and fuel system. The only (not even major) pick up was for the seat belt attach bolts for the lowered seat mod. These aren't included in the kit from Wicks because they don't know that someone is doing the lowered seat mod, so need two of the AN5-6A's and one matching nut to replace the longer AN5 bolt (and use its nut on one of the shorter bolts). So far, the Wicks kit has been very complete. Not sure about nuts for AN4 bolts though - I seem to have borrowed from the fuselage to put a few in the wing and borrowed from the tail to put a few in the fuselage, so I don't know where the total will end up. Higher cost items ordered included wheels, tires, an oil breather/separator, the mixture cable and gascolator. So major parts/systems remaining to be ordered are the propeller, oil cooler and its hoses, lights (tip markers and strobes only), flight instruments, engine monitor, wiring, switches, solenoids, cables, and connectors. So this won't be the last order, but it's getting close.
