Finished riveting, started adding the bolts. Did not rivet the upper (long) angle or its doubler plates because I need to fabricate and add the canopy latch striker plates. Should be easier to get these in if the upper angle is not riveted into the side panel. After about the 3rd bolt, realized the lower motor mount angle got shifted during drilling (3/16 clecos don't hold very accurately). Examined possibility of drilling as-is. Found this would leave ovalized holes. Decided this was not acceptable. Found enough 2x2x.125 stock in the scrap box to remake this motor mount.
