Marked and located air inlet opening on LHS forward fuselage side panel. Using the Van's air inlets. On recommendations from online group, located 1.5" lower than vent on RHS. This is to allow the throttle cable to pass over the vent. Now I'm questioning if the vent tube will interfere with the brake handle. Every solution breeds new problems.
