Rearranged sheet stock on the table. Found 1 sheet had dents along the edge, the other did not. The one that did not needed to become a wing skin. The one with dents could be used for the fuselage bottom skin since the dented sides of the sheet were not needed. Decided to layout the sheet with the fuselage bottom before laying out the remaining wing/h-tail skin sheet because the sheet with dents was on top, and I did not want to move an entire sheet by myself. I have been proceeding through cutting the sheets by unrolling them on the table, and not removing them from the table except by cutting them up and removing the pieces.
