Don helped turn the wings around on the wing stand so the flaps hinge side (bottom side) was facing out.
Installed the flap pushrods into the wings. Cut the hinge pins to length. Inserted the hinge pins into the hinge, then riveted the wing side of the hinge to the wings. Some have questioned how to get the hinge pins in after the hinges are riveted on - answer, you don't. Put the hinge pins in, then rivet the hinge on the wing.
No step sticker on the LH flap. Have one for the RH as well.
