Completed the major assembly of the LH wing. Started by turning it right side up, leveled it at the inboard and outboard sawhorses. On the inboard sawhorse, had to use spacer blocks on the spar, or the level will sit on the aft edge of the spar cap instead of the center peak. Set the upper aft skin in place, took about 45 minutes to rivet it on. Took about 2 hours to rivet on the forward skin. Set it in place on the upright wing and clecoed the trailing edge, top and bottom. Then clecoed the top side of the ribs and riveted the upper aft edge and upper ribs. Then turned the wing over, clecoed the lower ribs, and riveted. Set the wing on the wing stand - the wing stand seems to work really well.
LH wing on the rack.
Another view. Strapped on for security.
Aileron in place - this determined height of rack.
