Sonex 815 Build Logs
Date: 2-3-2007
Number of Hours: 5.00
Brief Description: Wing assembly
Took 2 hours to go get another riveter. Got this new one from Harbor Freight, which is quite an expedition from this side of town. Took about 2 hours to finish riveting the leading edge ribs and the lower aft skin. Had to drill out about 10 rivets in the leading edge-to-spar rivets because they would jump back a little when being pulled, leaving the head away from the rib. Two of the -6's (near the root end) were the worst. Drilled them each out about 4 times. Not sure why these were so rotten, but be sure to press the riveter in hard when pulling these. All these are on a bit of an angle for the puller, so I used an angled spacer and bent the rivet shanks. I'm sure these work arounds weren't helping any. After a while of this, left the bad rivets as they were and got all the rib rivet holes filled. Then went around and riveted the lower aft skin on, to get a good dose of successful riveting. Don helped with putting the rivets in the holes and removing the clecoes as I pulled rivets around them. Then after he left, I went back and drilled out and replaced the bad rib-to-spar rivets. Took the last hour or so to install the conduit in the forward ribs, the long aileron push rod, the bellcrank access cover plate, and clean up.
Riveting for lower aft skin and leading edge ribs completed.
Installed conduit.
