Installed the forward wing skin on the LH wing. Got the upper portion of the skin lined up and partially drilled. Bought some ratchet straps and a strip of wood to cinch down the lower portion. Got the lower portion tucked under the aft skin so the holes in the aft skin can be used for the main spar hole locations.
Top of LE skin partially drilled, bottom tucked under.
