Finished pilot drilling lower aft skin to RH spar. Unclecoed lower aft skin to access #9 rib clips. Drilled these into place on the upper skin. Clecoed lower skin back into place. Now need to flip it over, uncleco the upper skin, do the #9 rib clips to the bottom skin and figure out a way to do the hole in the lower skin for the tie down bolt.
