Finish cutting out 10 fwd wing ribs. That's all of them. Cut out 2 aft ribs from one sheet. Laid out 2 sheets with 6 aft wing ribs each, 1 lower aft fuselage side each, and 1 upper aft wing skin each. 3 of the ribs on each sheet fit easily, the other 3 barely fit after some rearranging. Then proceeded to cut out these two sheets - the 12 aft ribs completes those. Quite a tiring day - all cut using the little left cut red-handle shear. (anyone for digging a well with a pin or moving a mountain with tweezers?) Laid out the 1 remaining sheet I currently have with the two turtle deck skins, plus a section left over for the vertical tail skin and a wing tip (not laid out, just set aside). There will be 3 more sheets to order after all this is processed into parts.
