Installed the automotive compass on the glare shield. Installed the larger portable clock - stuck this on the kneeboard because there isn't a convenient place to velcro this to the panel without making a little tab to velcro it onto. Pulled the cowling, torqued the prop. Wasn't too far down. Most were 180-200 lb-in. Tightened all to 225. Checked tracking - good. Added the RH exhaust extension. It's at such a different angle that the cut line looks pretty dramatically different, but they are fairly parallel.
