0.9 flight time, 2 landings. Flew up to Eloy (E60) and return. Test of fuel flow with filter - much more stable. Seemed to be slight burble on the return, possibly due to the filter getting heat soaked. Have an idea on how to re-route the fuel line that is simpler than this setup that added the filter in place of the gasco. Flew at 6500' on the way up, 5500' on return. Showed about 154 mph ground speed up, 130 on return. Indicated about 140 each way. Prior to flight, added tape over the outboard wheel pant fasteners as a temporary secondary lock. This worked, but I need to make some tab washers or something.
