Sonex 815 Build Logs
Date:  7-26-2009
Number of Hours:  0.50
Brief Description:  Interior side panels
After the flight, installed the LH interior side panel. Started by relocating the trim cable about 1" farther inboards to clear the panel. Getting the panel in is tight because it has to flex/bend to get around the throttle handle. Fortunately this panel is thin enough that it clears the canopy latches without any cutouts or anything.
Left side panel installed.
Trim cable has a little more arc to it than I recall.
