Entry 1 for today: Torqued the right 3 cylinder heads. Torqued all 12 spark plugs. Reinstalled the baffle on the RH cylinders. Left the LH cylinder baffle off to change the oil filter. Still need to change the filter and refill the oil before a test run to check that the oil is staying in all the places I had opened up over the last week.
