Last night worked on a pattern for the interior side panels. The "spare" F-12 came in handy (surplus forwards fuselage side in the garage). Stopped by the airport this morning for a little trial fitting. Some like a big panel that covers all the structure. I think it will be fine with some of the structure showing. This will fit outboard of the rudder cables, so those will be visible, and it stops short of the spar box angle, so the structure will show ahead of that. Looks like I'll have to drill another hole a little more inboard for the trim cable. Not sure if I want a map pocket on this or not. Maybe on the passenger side. And the car plate showed up today.
