Sonex 815 Build Logs
Date:  10-31-2008
Number of Hours:  0.50
Brief Description:  Engine run, misc.
Figured out that the GPS wasn't getting power because I didn't reinstall one of the leads on the power plug after the fuel tank remove and reinstall. Got that in place, so now the GPS will run off ship power and the screen won't go dim. Also set it to statute miles. Tweaked the rudder trim tab a little more since the ball is right of center. Rolled it out and ran the engine for a minute or two. Doesn't appear to be any leaks, but past ground run tests have looked like this. Wind was up, so no flight this morning.
