Brief Description: Fitting in oil filter spacer ring
Installed a new fitting in the oil filter spacer ring. Used epoxy to seal it - the threads hold it mechanically. Hopefully a little epoxy instead of the various goo and goop will seal it for good. If not, I'm buying a new spacer ring.
