Added safety wire to the gascolator bowl. Bonded the engine data plate using JB weld. This is the revised "3300L" model plate from Sonex necessary to keep the hydraulic lifter 3300 Sonex in the LSA category. Used silicone hi-temp gasket adhesive to glue the left canopy trim forwards and aft ends to the canopy, since the Sikaflex was all dried up. Remade the lower left cowling pin from .075 music wire, since the hinge pin is quite tough to push into place.
