Mounted the exhaust pipes. Installed the retention springs and safety wired inside of each spring. Oiled the air cleaner. After a while to be sure the oil had soaked in all around, attached the air cleaner to the Aerocarb. Mounted the regulator and solenoid on the firewall. Looked at putting them on either side of the fuel fill box, but the overflow plate I put in the box can't be removed without pulling the vent fitting off the tank, which I don't want to do. The firewall locations I chose are pretty convenient. Need help securing the nuts on the aft side of the firewall, but they are all in place.
Air cleaner in place. Regulator and solenoid on the firewall.
