Made up the hinge pins for the sides, bottom, and top of the cowling. The bottom center I am using .075 music wire instead of the hinge pin because it installs more easily around the curve of the cowling. Already had the music wire cut to length.
Hinges with pins. Pins are longer due to where the access is.
