Spent about 15 minutes removing the tank-to-firewall fuel line and adjusting the bends on it and reinstalling. Took another 15 minutes or so to tweak the bend angle on the brake handle to improve clearance with the air inlet. Spend the rest of the time making the bottom cross beam for the panel, plus verticals for the avionics "stack". Took a chance on the depth for the com, though I had seen a photo of one installed like this - the antenna lead clears the fuel tank by about 1/2", so it's really not super tight in there.
