Sonex 815 Build Logs
Sonex
W10
Main spar webs
Drilled the 2nd .125 spar web. Made the cuts in the 2nd .090 and .125 webs, but did not file/sand/scotch brite the cuts.
Drilled webs while still rectangular, then marked for the smaller cuts. Easy to line up like this.
The small amount cut from the .125 web - dim. is different at each end, so check print!
Marked angle cut on other side of the part.
Sonex Home
1491
Cowling
142
107
Flights
111
141
441
43
Panel
361
