Hung the vertical stabilizer on the wall for safer storage. Started work on the rudder assembly. Already had the skin cut, but deburred it and drilled the details to it. Not a whole lot of parts here. The ribs fit right on (no tension or squeezing in the skin) because they were line on line with the print. If you bend up these ribs and they aren't right on to the print, do over. There is no bulging or squeezing of ribs either into or out of the skin.
