Parts arrived for the tank today. Put the tank together with clecos and determined which rivet holes needed to be enlarged to fit the next larger size rivets. There were several. I determined this by the cleco needed to mary the pieces together. I circled the one needing this with red marker. Later, I disassembled the tank and redimpled the larger holes. As for the other holes, they were redimpled with a tank dimple die set from Avery tools.
Interestingly, not one rib had been dimpled previously.
