Spray washed the wing skins. It all came of fairly easily with a few acceptions. I need to put more solution on a couple of spots I missed.
I stripped the majority of the proseal off the remainder of the stiffiners and covers. I did one rib. Once this was done, all these parts were put into a tin and coated with EFS 2500. I will let this set for a day or so. They will need to be scrubbed and cleaned.
Kept each set of stiffeners and covers in different vats. Each got the first coat of EFS 2500
