Working upsidedown here, I managed to get the upper nose gear box installed with hot glue. It took a few tries as I guess the plans templates aren't exactly correct. Some refitting had to be done.
In the third picture, you can see I've installed a wood block in both of the box sides. Originally the one for the left side was in there for the adjustable pedal anchor mount. I'm installing dual pedals in my plane, so I wanted to have an snchor over there as well. My pedals will also hang instead of bolt to the floor, but more on this later.
