So I squeezed when I shouldn't have. Now I'm fixing a boo boo from when I layed up the lower skin on the LH wing. I used a square tube as a straight eged on the TE... 1) I didn't need to and 2) it really screwed up the TE where the pressure was on the clamp. I knew better. Oh well. What's done is one. Now I spent the night making straight pcs to go between the jigs to hold the TE straight, bondoing the wing to those installed pcs and then sanding (the glass) where it protruded above where the top skin would be. Tough to show without a pic, but it's not all that bad. Penalty will be a bit of weight where I have to reinforce the lower skin where the glass is sanded away.
So much for a better way... Again, what was I thinking!
