Got the rest of the parts completed that make up the NG-1 assembly and assembled them to make sure everything works right. I didn't have the steel tubing to make the linkage rod, but I used aluminum. I'll have to order a peice of steel to replace it with.
Make the cable a bit long, and then twist it to shorten it No more than 3 or 4 twists should be used in a cable this short - but that buys you about .050 length adjustment.
