It's warm here in the south - still about 80 as I write this. Rediculous.
Anyway, spent a little time cutting out and alodining the CON brackets for seat belt attaches... Made CON-6 (a new part) since I'll need them for mounting the 3 point harness I intend to use.
Spent the entire rest of the evening laying out the axle mounts and getting the BID pads installed and oriented correctly. This wasn't hard, it just took time to triple check to make sure everything was correct.
