Brief Description: Riveting the Vert Stab Substructure
I Clecoed all rear spar parts together (VS-803, VS-808, VS-410, VS-411, VS-412) and taped over the holes reserved for the rib attachment. All of these parts were then riveted together. Clecoed and riveted the front spar and ribs together (VS-704, VS-705, VS-706, VS-707). Then Clecoed the skin (VS-801PP/VS-901) to the forward spar/rib assembly. You can see where I ran out of the old primer and began using the new. I didn't feel it necessary to strip the old since it will be inside the stab and not visible.
