EJ Andersons RV-8 Builders Log
Date:  3-31-2012
Number of Hours:  4.20
Manual Reference:  Section 6
Brief Description:  Riveting the Horizontal Stab
Riveted HS-609PP bars to the HS-603PP rear spar channels using AN470-6 rivets.
Riveted HS-412PP hinges to HS-603PP channels using AN470-7 rivets.
Riveted HS-413PP hinge brackets to HS-603PP channels uning AN470-5 rivets.
Bolted HS-411PP center bearing to the rear spar using AN3-5A bolts, AN960-10 washers and AN365-1032 nuts per construction plans. Attachment bolts were torqued to 25 in/lbs.
Image 1 shows the completed rear spar.
Image 2 shows areas of the reinforcement bars where the primer is not sticking. I will clean off as much of the flaking primer as possible, clean the affected areas and reprime.
Image 3 shows the forward side of the rear spar. The yellow tape marks the holes where the ribs will be attached. They are empty holes for now.
Assembled Horz Stab rear spar.
Areas of flaking primer.
Rear Spar Rib attachment areas.
