DARREN'S WEB SITE
Date: 11-18-2019
Number of Hours: 6.00
Brief Description: Connected the battery...
Removed the carbon throttle cover and tweaked to make the throttle lever run smoothly, thetidied up the last few jobs of wiring, including fitting the C-Amp plugs for the wing root wiring, then decided it was time to connect the battery.
Disconnected evry avionics plug, and connected the battery leads, and it seemed to work... took me a few seconds to realise that the loud whirring at the front was coming from the fuel pump that Id left switched on!... thenI turned the battery master off, at which point the battery contacter went mental, some of the avionics started squarking wildy, and it all went a bit wrong!
disconnected the battery, dropped the bolt down amongst the pitch autopilot servo, and spent two hours looking for it!
Went to bed to ponder on why it wasnt working... no help at all ont the internet...
Copyright © 2001-2020 Matronics. All Rights Reserved. |
