DARREN'S WEB SITE
Date:  9-4-2019
Number of Hours:  9.00
Brief Description:  Panel work
More panel work, fitted the flush mount for the G5, modified the 507 autopilot mount to make it flush mount, filled and sanded the rivet heads, added the ELT switch panel, and the two dimmer switches for the panel and cockpit lighting. Primed the panel and got it ready for final paint/carbon dipping.
Finished the panel attachment to the frame.
Started to sort out the wiring... amalgamated the ground leads ( except the avionics leads) and figured out how to route the conduits out of the gear tower.
