DARREN'S WEB SITE
Date:  3-23-2020
Brief Description:  Prop governor setup, idle set up
Took the cowlings off so taht I could tweak the idle setting... taxied around the airfield to warm the engine, then set it to 730 rpm... any lower, and it sometimes cut out.
'ecercised' the prop governor and nothing happened... half a dozen times!
Phoned my Inspector who advised me to keep cycling it as the oil probably hadnt circulated enough yet. after 10 minutes, it started to work and seems fine now.
Cowling put back on...
