DARREN'S WEB SITE
Date:  4-17-2019
Number of Hours:  3.00
Brief Description:  Exhaust fitted
decided to put the exhaiust on whilst waiting for the fibreglass to set on the wheel fairings.
Initialy I thought the exhaust wouldnt fit, then realised that the rear exhaust element was on a ball joint, and just needed nudging into position.
Anti-sieze compound put on studs, and nuts torqued up. Next step was to assemble the pipe ball joints, and then attache the rear support brackets. One connects to the rear outer stud that attaaches the sump to the crankcase, and the other bolts to the lower engine mount support.
