DARREN'S WEB SITE
Date:  12-8-2019
Number of Hours:  4.00
Brief Description:  Battery leads, aerial changes
Stuck in the back of the plane again.... Swapped the DME antenna cable and moved the DME antenna to the starboard wing. Original re-purposed as the ADSB-in for the new traffic monitor.
Fitted the battery charge cable, and removed the ELT to see if I can make it work. Despite never being used, the battery appears to be flat!
Tidied up the cables to the transponder and DME.
