DARREN'S WEB SITE
Date:  4-5-2019
Brief Description:  Ran wired from Flap sensor to panel
connected the wires from the flap sensor along the starboard side upper conduit to the front. Fitted the fireall 'eyeball' seal for the cable to the main buss.played with the positioning of the 70A and 30A circuit breakers and they look good. Normal operating range goes to 85 degrees C, so I'll check with manufacturer as they may need a cooling hose.
