DARREN'S WEB SITE
Date:  4-4-2019
Number of Hours:  3.00
Brief Description:  Baggage tie downs and Flap position indicator inst
Bagge tie downs installed... bit of a bugger to do the front pair, as the floor was rivetted in and I couldnt reach to fit the steel backplates. After some head scratching, I used a magnet to drag the steel back plate across the floor into position, and then used riv nuts to fix the mounting brackets. The rear two were easy, and just needed nuts and bolts.
Made a bracket to mount the flap position indicator, and found the 'sweet spot' wher full flap travel corresponded to full indicator travel. Who knew that schoolboy trigonometry could come in handy!
(The attach pint is 1 15/16" from the centre of rotation of the flap torque rod)
Rear baggage tie downs
Flap position indicator installed
