DARREN'S WEB SITE
Date:  12-15-2018
Number of Hours:  6.00
Brief Description:  Prep for painting
All inside primed areas sanded with 400 grit, then washed and degreased ready fo r painting on Monday.
Re-arranged the workshop in readiness for a bif day of spraying later
Started fabrication of the rear avionics shelf to mount the ELT. Decided to put the Aspen MFD RSM there too. I guess the Garmin megnetometer can go theere too, as its far enough away from the pitch servo to be ok.
