DARREN'S WEB SITE
Date:  10-25-2018
Brief Description:  Fastback side rail attached port side
Fitted the nutplates to the Fastback side rail on the port side, and rivetted it on using alternate rivets as per plans.
Left the rivets to the front seat support weldment as this will need some welding work later on, and will probably take it off for that to be done.
Trimmed the Fastback fibreglass panel cover and trila fitted.
Had some doubts about the wisdom of fitting the front top skin yesterday, but there is so much more access on the FB kit tahn on the standard front skin. Hopefu;;y there will be sufficient access later on. The Fatsback installation guide on line shows the kit being installed at my current build stage, so I hope it will be ok.
