Got final approval to fit my 'Control Approach' rudder pedals after stress testing them to 200kg... Bitch of a job working around the stick and under the panel! Fitted the extra tube to restrict forwards movement of the adjustable pedals, in order to comply with the 'repeat mod' ofr use of dual brake cylinders, one mounte on each rudder.
Tediously fiddly to drill and rivet the ring on, whilst in position under the panel.
