Brief Description: Wing bolts finished, SB wiring and tips added
Inserted the SB short wing root bolts ( the ones on the service bulletin) Connected the rear air ducting to the wing NACA. Tidied up the wiring in the root so taht the aileron push rod doesnt rub on the wires. Installed the SB comm aerial Installed the DME co-ax Installed the SB ZipTips, and ready to check the wiring tomorrow.
