Flaps connected, actuator rods reinstalled and checked. Great fit.. will be happier when the G3X movement limits are set! Ailerons connected and adjusted. The stripped thread wing bolt was removed easily with a nut splitter, and replaced with a new close tolerance bolt. All torque settings on wing bolts checked. Front and rear wing mounts finally installed. Mustnt forget to 2 AN4-11 bolts on the rear of the main spar!
