Fitted a second ammeter shunt to measure current flow to/from the battery. fitted connectors to the Air 7 coax for the bottom Flarm aerial, mounted the aerial. Did some paint prep for the ELT antenna support mount/ground plane. Configured the CO monitor and the heated pitot control system.
Not much room behind the panel. additional fan installed to dissipate heat
