Brief Description: Wired the heated seats and the rear USB ports
Fitted the switches and wiring for the front and rear heated seats. fitted the rear stick trim button connection, drilled the tube for fitting the retaining bolt, then fitted the rear stick boot. Decided to add a 2 port USB to the rear.
