Changed the cut out in the right side switch panel as the USB box wouldnt fit at the front.. neeed to add a couple of switches to fill the gap, but it looks good
So many wires to each switch...
the flap/pich servo/roll servo need to be 'on-line' when the switch is in the 'off' position, and off line withe the light illuminated, when turned to the 'isolate' position. Had to order some more switches!
