More work on the elevators and control rods after sortingout the errors earlier Set up the laser levels to measure the elevator movement, then made 'stops' to ensure correct range. Final measurements are 30 degrees up (maximum allowed) and 23 degrees down (allowed range is 20-25 degrees)
