Brief Description: Oil shutter installation and fitting the oil coole
Fitted the oil cooler shutter to the rear firewall, with a spacer made from heatproof silicone rubber. Fitted the rubber seal to the oil cooler shroud, then attached the shroud and cooler to the mount, bolted onto the engine mount. Fiddly job! Glad I didnt get the part carbon dipped, as it ended up scuffed. Will touch up the paint tomorrow.
